tpi to non tpi ?
Old Aug 28, 2005 | 01:38 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
Axle/Gears: 7.5" 4.10
tpi to non tpi ?
i am thinking of swapping my 305tpi for a 377 stroker and i have a set of aluminum heads from an 88 tpi corvette and the whole intake system but if i went carbureted it would be a whole lot cheaper to make more power but i am not sure if the carbureted idea is even feasable cause it is an 87 iroc 5spd but i don't want to look at a check engine light all the time cause certain sensors aren't hooked up. bassically this is my first tpi car and not quite sure what i need to make a 377 run right with the injection setup any info would be appreciated. thanks in advance.
Old Aug 28, 2005 | 03:57 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Re: tpi to non tpi ?
You wont have a check engine as long as the ECM is removed.
Old Aug 28, 2005 | 05:31 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
or the check engine lightbulb
Old Aug 28, 2005 | 09:16 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Yup remove the bulb. I just did tpi to carb swap and its the best thing I've ever done. Want the car for performance without spending a load of money on intake=carb. Want a daily driven car, and happy with performance=FI BTW you'll also need a adjustable, bypass style fuel pressure regulator. I used a holley http://holley.com/products.asp?product=12-803BP it was like $70 cad or something
stalkier
Dec 6, 2015 11:25 PM
gixxer92
Sep 1, 2015 04:32 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
