in the box vortecs
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
in the box vortecs
Has any body out there heard of the brand new aluminum vortecs w/68cc chambers? Is there valve lift limit prob w/ these as I have read in other threads? Like 470 My buddy who is an engineer for gm say they will be the bomb for my 383 stroker that is being built as I write, I'm getting close to buying intake & want to know if anyone has had experienced these? They go for $1100 in the jegs I do believe and I got them for 600
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
For 600 bucks run em anyway. If ya have to swap out the valve springs. Go by your cam manufactures suddested valve spring.
in the box vortecs
thanks welsh I have found some more info on these fast burns and I do think they will work just fine
Transmission: 4L80E/4L80E
The winning magazine engine masters challenge small block a couple of years ago used those heads, reportedly out of the box (the rest of the engine was anything but).
86CamaroDan
Sep 29, 2015 10:08 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
