Help with transmission (Wont go in)
Old Oct 3, 2005 | 12:10 PM
GTA350JAG's Avatar
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
I just bolted my motor in my iroc but I cant get the transmssion to go to the motor. It lines up but it is like an inch and a half away from the motor but it wont go foward. The crossmember is off but the torque arm and driveshaft are still in. Is this why I cant get it to go to the motor? It is jacked up and I just cant get it to go anymore.
Old Oct 3, 2005 | 01:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Verify the torque converter is engaged in the front pump properly. It needs to be well back from the bell housing mount plane.
Make sure everything is axially aligned as well. And nothing is hanging down inbetween the engine and transmission. An inch and a half sounds like more than the alignment pins, but you need to be sure. Could be the nose of the TC isn't aligned with the crank.
Do you have the engine mounts bolted in already? If so, I'd take the driveshaft and torque arm off and try manipulating it without those things constraining the process.
By the way, why was it apart?
Old Oct 3, 2005 | 04:24 PM
GTA350JAG's Avatar
I got the transmission in we just had to lift the block up and pried the tranny in with a bar. Im the one doing the vette motor swap and this is the first time i am doing a swap on my own car so its taking some time for me to do it. The motor and tranny are bolted in the wireing is getting done now then i have to bolt up the y pipe and do some other things. I will keep posted if i run into anymore problems which i will. Thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
