hawks 350tpi
Old Nov 9, 2005 | 04:58 PM
1bad88droptop's Avatar
Car: 88 camaro drop top custom
Engine: turbod lt1
Transmission: t56
hawks 350tpi
i am thinking about gettin the used 350 tpi engine from hawks for 1200, for my 85 sc, do u think this engine is a good deal and would my 700r4 from my 2.8 bolt up to it?
Old Nov 9, 2005 | 05:13 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
The shipping might b the deciding factor on this one, you might be better off looking locally. You will also need a harness and ECm to make it all work together and correctly. your transmission will also need to be swapped out because of the different bolt patterns
Old Nov 9, 2005 | 07:53 PM
Engine: turbod lt1
Transmission: t56
ok, well it comes with the harness and ecm, but there trannys used r 300 so im talkin 1500 plus shipping so ill check on shipping but does this sound good?
Old Nov 9, 2005 | 07:55 PM
meridius's Avatar
Id chack on that shipping, Im sure you can do better, Im not nocking Hawks at all here but I say that the engine can be had cheaper, Ive seen entire cars wrecked go for that so its all in where you look.
Linson
Oct 24, 2025 02:00 PM
Fronzizzle
Feb 9, 2017 09:31 AM
F-body-fan
Nov 4, 2015 06:13 AM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
