ANY ADVICE......
Old Nov 23, 2005 | 03:13 PM
pro_tryer's Avatar
Car: 1985 Camaro
Engine: 301 V8
Transmission: 4 speed manual
Axle/Gears: not sure, limited slip tho..
ANY ADVICE......
im sure there is a post for it, if so, which one, if not, what manual transmissions will fit a '76 350 sb? im lookin to do my first engine swap, from a 2.8 to a 350. i am rebuilding the engine also. any advice, suggestions, criticisms are welcome.
Old Nov 23, 2005 | 03:45 PM
TexasLT1's Avatar
Car: '92 RS
any manual transmission that will bolt up to a SBC.
V-8 T-5 will bolt up to it no problem.
Old Dec 1, 2005 | 07:02 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
t-5 , m 21, m 22 , t-56, etc.
there are many manual transmissions that will bolt up to it and as said above any manual transmission that bolts up to a sbc will work ....but you will need to find one that will accept a torque arm or buy the bracket kit from summit or somewhere...
