tbi swap into carb car?????
Car: sexy
Engine: ??????????/
Transmission: 4l60e
we are putting in a tbi truck engine into an 86'
trans am, but don't have the ins and outs of the wiring needed
or even where the best place to start
the fuel pump have been done but we are not sure of the rest like if the stock cluster will even work
anyone have the conversion info for us please we are ready to go except for this
links what ever you have thanks.
Transmission: 4L80E/4L80E
Welcome aboard.
Did you get the entire TBI system from the truck? Meaning all harnesses, sensors, ECM, etc. If so, then basically all you have to do is put it in the car. Some harness lengths and routing may be strange, pass-through holes may be different, etc., but all you have to do is be inovative about getting it done.
Or, go to a junk yard and get the same stuff from a 3rd gen TBI. Should be fairly easy to find. Could probably find the same on the Classifieds forums on this Board.
More details of what you're up against are probably available on the TBI forum.
theshackle
Mar 5, 2017 06:37 PM
