need more hood clearance
Old Jan 22, 2006 | 08:32 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Hey guys im gonna be puttin my 355 that was in my old formula in my new formula. My biggest problem was that i had to run a rediculously small air cleaner because of the dual plane intake manifold. I really dont have the money to buy a new hood. I was wondering if there is a company out there that makes low profile motor mounts. i only need about an inch more clearance to fit a normal sized air cleaner. or if anyone else has any ideas about how to get this thing to fit im all ears.
Old Jan 22, 2006 | 11:25 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've heard where alot get the OEM BBC air cleaner housing - it's supposed to clear the hood, and the linkage.
I got a drop base cleaner housing from pep boys, but I had to add a 1/2 inch spacer under it to clear the linkage and choke, and then switch to a 2 1/2 inch element. I have the Performer RPM and edelbrock on a 350 with new poly motor mounts and that was the only thing I found that worked (I had no luck finding an OEM BBC housing 'round here).
Old Jan 22, 2006 | 04:16 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I cut away some of the hood bracing for my HSR install, gave me about 3/4" I'd say.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
