flexplates?
Old Feb 5, 2006 | 01:05 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
flexplates?
Does anyone know if there is a difference as far as crankshaft balance for an L31 block and an L98 block? The L31 is 168 tooth flywheel where as the L98 is a 153 tooth flywheel, but are there weights on the 168 tooth flywheel or is it internally balanced on the crankshaft?
Old Feb 6, 2006 | 02:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you get a one-piece rear main seal flexplate, it will be properly balanced whether 153 tooth or 168 tooth, whether 305 or 350 or L98 or L31.
Old Feb 6, 2006 | 05:22 PM
vortec77's Avatar
Car: 86 T/A
Thanks for the response five, so it doesnt matter if its an internally balanced crank or if the flywheel has weights on it as long as its a one piece rear main seal.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
