5.7 out of a 1992+ suburban, intake question
Old Mar 25, 2006 | 07:47 AM
EaTeR's Avatar
I was told that this late model 5.7 may need a different carb intake if I were to convert it from the stock TBI to carburator.
Is this true? And if so, could someone pinpoint the one I need off jegs/summit?
Old Mar 28, 2006 | 03:16 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
edl-2104 would be the one i would pick for your truck given low cost and low end torque need for a large vehicle. summit has an array of intakes and a search you can put in your vehicle and they will tell you what fits.
your engine is not really late model they made them from 87-95.
Old Mar 28, 2006 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '87-'95 SBC heads have the center two intake manifold bolts at 72 degrees, vs. the 90 degrees of the rest of the bolts. The '55-'86 SBC heads had all of the intake mount bolts at 90 degrees. That's the only difference.
Many people have elongated the center bolt holes on each side of a '55-'86 manifold to fit on the later heads. Whether you buy an intake ready to go or modify one of the earlier types is up to you.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
