question on heads for ne1 that knows (five-7 maybe)
Old Apr 5, 2006 | 08:32 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
was wondering if anyone has or knows where I can get the flow numbers on a stock set of bowtie phase 2 034 heads and also possibly 18 degree aluminum in stock form also. I don't know if this is the right forum for this but couldn't think of anywhere else. Thanks
Old Apr 5, 2006 | 10:17 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Try google.
Old Apr 5, 2006 | 10:57 PM
jstoltz's Avatar
helped somewhat but anyone that has them now I would like to see some numbers they got.
Old Apr 6, 2006 | 12:50 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
062 L-31 034 BOWTIE
IN EX IN EX
VALVE
LIFT
.100 69.2 50.4 67.1 75.7
.200 146 101.6 138.2 120.4
.300 195.2 135 195.2 137.8
.400 222.3 146.9 229.5 165.9
.500 227.7 148.2 245.7 169.3
.600 230.1 148.5 231.8 170.5
Old Apr 6, 2006 | 04:16 AM
jstoltz's Avatar
that's what I'm looking for. I popped the numbers into my desktop dyno compared to the other numbers I had and my combo doesn't really change. peak numbers don't move. I am hoping this thing will run right when I actually get a chance to work on it. (406 with bowtie heads edelbrock rpm air gap intake holley 650 dbl pumper rebuilt by quick fuel and lunati bm2 cam .480/.480 Hedman 1 5/8" into 3" ) still have to figure out how I am going to do the fuel lines. If anyone has any recommendations feel free.
Old Apr 6, 2006 | 01:42 PM
F-BIRD'88's Avatar
larger carb 750+cfm could go to a proform hp style main body.
Cam is too small. Go with a solid mechanical comp XS282-10 is good #12-678-4
Old Apr 6, 2006 | 01:53 PM
jstoltz's Avatar
that's kinda what I thought on the carb so I will more than likely get the holley main body. which cam would you go for? It is setup for street which is the reason for the smaller cam and carb. wanted to be sure I still had vacuum left for brakes. but may still change it. but carb has been going through my head the whole time.
Old Apr 6, 2006 | 10:46 PM
F-BIRD'88's Avatar
Power brakes will be ok but that cam requires a modified distributor advance curve and a high stall converter. 3000 minimum 3500 best.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
