62-67 327 swap into an 86 firebird
Old May 12, 2006 | 01:03 AM
86Firebird86's Avatar
Car: 1986 Firebird
Axle/Gears: 9" Moser with 3.85
I have just recently finished building the engine and dropped it into the car, and when I went to fire it up tonight to break in the cam it wouldn't fire. When I pulled the valve covers off and checked the valve set, some of the valves were way out to lunch. So I reset everything again and tried firing it again and the same thing some of the valves were all wacky again. Also when my choke closes fuel shutes out of the carb. Has anyone had this problem before or knows what might be happening?
Old May 12, 2006 | 06:08 AM
Sounds like (1) the valves aren't adjusted right; and (2) the distributor is installed 180° out of time.
Old May 12, 2006 | 03:45 PM
Car: 1986 Firebird
When I went to reset the valves again I noticed that the rocker studs on the loose rockers were a bit higher than the rest, so I took the rockers off #1 valves and put a straightedge on the studs and sure enough there was a difference in height. So looks like the engine won't be running for a while yet. Thanks for the info.
xkingcodex
Feb 12, 2020 07:43 PM
masonta
Aug 31, 2015 10:14 PM
E Rod
Aug 28, 2015 05:17 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
armybyrd
Aug 10, 2015 09:23 PM
