would i need it or not?
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
i have already read the swap threads, i was wondering if i bought this 82 camaro with the 4 cyl motor, do i need to upgrade the radiator, also i believe it has a th200 transmission in it, how long are those compared to a turbo 350, is that direct bolt in, and one last thing is the 4 cyl is tbi'd (i believe) could i just swap in a tbi'd 350 and it's ecu or is there more than that, i know the truck tbi'd v-6 you can just change the chip, and exhaust,and i know the th200 trans won't bolt up of course.
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Well, you have 4 cyl vs. 8 cyl, so you will need a different wiring harness/ECM along with a new tranny and radiator. I would plan on finding a junkyard V8 Camaro and stripping the radiator, wiring, ECM, sensors, transmission, motor/tranny mounts, etc. from it. It will be easier in the long run to have the correct wiring from the get-go if you ever have to troubleshoot anything.
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
