ZZ4 block and fuel injection (TBI)
Old Jun 15, 2006 | 02:20 PM
Casey_Butt's Avatar
Can a GM TBI system be easily hooked up on a ZZ4 Short Block? I mean, is there anything in regards to sensors, etc, on the "newer" fuel injection Gen 1 engine blocks that are missing on the ZZ4 block?
Old Jun 15, 2006 | 02:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That won't be your problem. The two main issues (other than exhaust and fuel flow) are mounting the TBI manifold on the '86-earlier intake bolt pattern of the ZZ4 aluminum heads, and PROM tuning for the increased displacement and more radical cam.
TBI forum is probably the better place to look.
Old Jun 15, 2006 | 06:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Use any intake designed for the old single bolt pattern heads 55-86. Slap a TBI-Carb adapter plate on it. Get the fuel delivery to a sufficient amount. Buy RBob's EBL and Craig Moates Burn1. Then program away.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
