piston rods
Old Jun 20, 2006 | 10:04 AM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
piston rods
so i will be redoing a 350 and its going to get bored .040 over and then put a 383 crank in it so can i use the stock 350 rods or will i have to buy new one?
Old Jun 20, 2006 | 10:45 AM
Yes you can use 350 rods; as long as the crank you use is designed for 5.7" rods. And of course, your pistons are set up for 3.75" stroke and 5.7" rods, which requires a 1.425" compression height.
Ed1LE
Sep 30, 2018 09:14 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
