just did a swap and no speedo
Old Jul 1, 2006 | 08:02 PM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
Hey guys I just did a swap and my speedometer is not working I have an 86 TA with a 700r4 tranny electric speedo...... I pulled all the emissions stuff but still have the wires in the car. I only have six wires hooked up from the passenger side harness the four for the tranny and the two for the speedo sensor in the trans. From the reading that I have done I seems like it should still work but it's not. Any suggestions greatly appreciated. Please guy help would really be appreciated
Old Jul 1, 2006 | 08:08 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
First question is what did you swap? engine trans...etc as to the wiring are you speaking primarily about the trans wiring, as far as your speedometer is concerned you should only need the speed signal hooked up for the speedometer to work, ( the two wire sensor on the tailshaft ).
Old Jul 1, 2006 | 08:11 PM
Car: 86 TA
Engine: 305 carb
I did an engine swap 305 ccc q-jet to a 350 carb and the two wire sensor is plugged in..... on a side not my fan doesn't kick on either
Old Jul 2, 2006 | 03:55 PM
Car: 86 TA
Engine: 305 carb
ttt
Old Jul 2, 2006 | 04:03 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
fan doesn't kick on.... what year is the 350 block.. does it have the coolant fan switch? maybe you have an extra plug that was never reconnected
Old Jul 2, 2006 | 06:29 PM
Car: 86 TA
Engine: 305 carb
the sensor is on one head the switch is on the other and they are both connected its an 86 block
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
