v6- LT1 transmission?
Old Aug 7, 2006 | 06:39 PM
CAM954's Avatar
My goal is to put the LT1 in my currenly v6 86 camaro.
I read the posts on going from v6 to v8 and 3rd gen to lt1. I didn't see there being any problem with hooking up any of the transmissions.
The question: Can I bolt up the v6 t5 tranny to the LT1 engine?
This will only be a temporary thing until I get the transmission that I want. I know that I'll tear that v6 t5 up if I left it behind the bigger engine for too long. I just want to know if it will work.
Old Aug 7, 2006 | 06:43 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
You will need a v8 bell housing. Mike
Old Aug 7, 2006 | 06:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
The V6 bellhousing won't work. The V6 input shaft is smaller than the V8 shaft, so you'll have to use a V6 sized hub clutch disk.
Of course, the word "work" is subject to intrepretation. Stay off the gas, and the V6 T5 will probably "work" for a long time. Get on it, dump the clutch, speed shift - you'll be walking home before long.
Old Aug 7, 2006 | 07:18 PM
CAM954's Avatar
Thanks for the replies. It looks as though I should probably just get the transmission that I want before installing. Will the 6 speeds that were put behind the LT1(I think called T-56) bolt to the origional crossmember and stabilizer bar thingy?
Or would it be easier to go with a v8 t-5 that will bolt up to everything?
Old Aug 7, 2006 | 09:25 PM
CAM954's Avatar
never mind, found my answer. Here is link if anyone else was interested.
T56 6 Speed Conversion for 82-92 F-bodies
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
L0tuS
Oct 4, 2015 08:07 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
L0tuS
Sep 4, 2015 11:16 PM
