small vs. big distributor
Old Aug 19, 2006 | 11:06 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
The stock 305 in my 88 IROC has a small distributor with a seperate ignition component on the side. I'm in the process of putting in a 350 from an 87 Vette (cheapest 350 I could find and the alum. heads had me sold) but it has the larger distributor cap w/out the ignition component. Does anybody know if this will require wiring changes or if this will be a problem? Thanx in advance.
Old Aug 19, 2006 | 11:09 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Welcome to the boards. Why don't you reuse you factory distributor? That seperate component is the coil.
Old Aug 19, 2006 | 11:14 PM
Car: 88 Iroc-Z
Axle/Gears: ??
I didn't know I could re-use the old distributor. I'll check and see what I need to do to put the coil on the engine that's going in.
Old Aug 19, 2006 | 11:19 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I am assuming they are both TPI engines. You would have to reuse your distributor and factory wiring.
Old Aug 19, 2006 | 11:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes the distributors will fit all 1955 and later sbc engines
the coil mounts to the intake manifold in a bracket on the TbI engines but im not sure on TPI engines,
good luck
Old Aug 19, 2006 | 11:41 PM
Car: 88 Iroc-Z
Axle/Gears: ??
Thanks, I'll keep my progress posted
Old Aug 20, 2006 | 11:24 AM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
or buy an msd billter one, they're nice
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
gixxer92
Sep 1, 2015 04:32 PM
Out-Cast
Aug 17, 2015 10:57 AM
cstrobel65
Aug 15, 2015 10:19 AM
