Surface rust on connecting rods ,need help
Old Sep 22, 2006 | 05:18 PM
Rocksiroc's Avatar
I am building a 383 and i was just about to start assembling it. Then i looked in the box where my rods and pistons were and noticed that the rods had surface rust on them. I had them in my garage, i was told to lightly sand them and oil them. Before i assemble should i clean them with soap and water or do they need to be professionally cleaned. The parts are brand new 5140 forged, i bought the rotating assembly from powerhouse. The pistons are already pressed on to the rods also. Can anyone give me advice on going about this pita problem.
Old Sep 22, 2006 | 06:39 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
use steel wool, scotch brite, or a wire wheel to scrub the rust off. don't sand them, it wouldn't do a good enough job. then clean them off with carb cleaner or something and oil them.
Old Sep 22, 2006 | 10:07 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
If its not on the bearing surface i wouldnt worry about it to much, I say steel wool or something. Before you assemble that engine make sure everything is clean with brake clean, and a clean lent-less rag.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
