To Rebuild or Not To Rebuild?
Old Sep 27, 2006 | 02:10 AM
LuBu_Z28's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L TPI
Transmission: 4 Spd. Auto
I have a '91 Z28 with a tired L98. Would it be better to replace it maybe with an upgrade(LT1 or LS1) or completely rebuild it.
Thanks in advance.
Old Sep 27, 2006 | 03:03 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
how much $$$ you got? How good are your wiring skills? Are you writing a check or doing it yourself in this budget?
Old Oct 3, 2006 | 11:28 AM
LuBu_Z28's Avatar
Engine: 5.7L TPI
About 6-8k, no wiring skills and possibly writing a check! Then again what would be better yet cost worthy?
Old Oct 11, 2006 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That is extremely subjective. Either way you go, you wouldn't get your money back if you turned around and sold the car. Would that mean neither is cost worthy???
If you're writing a check to get this done, you're probably better off getting your L98 rebuilt. You almost certainly wouldn't get an LS1 installed for that budget. LT1 may be possible. Then you'd have a stock LT1 - which isn't bad, but it would probably be used as well.
Rebuilding the L98 would probably run you around $2500 parts and labor. You could spent the rest of the budget on things like exhaust and TPI upgrades.
Old Oct 14, 2006 | 01:23 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Check out Jim Pace Performance Parts: 350 roller-style GM Performance Parts short block for $1150 shipped to you, brand new. You'll need a better cam, gaskets, and to get the heads rebuilt. Very cost effective in my opinion.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
