lt1 swap wiring question
Old Oct 7, 2006 | 11:38 PM
livefastkillslo's Avatar
i have searched and searched the forums for this info so i thought i would ask, i put a lt1 motor and trans (out of 95 impala with complete wiring harness and ecm) into a 92 camaro set the ecm to spear tech put headers on it and now i am trying to wire the car. i have the pin out diagrams for the 95 harness and i have the factory manual for the 92. my question is this- if i put power to the 95 fuse block and run a signal wire to the starter and fuel pump will it fire up??? any help would be great.
Old Oct 9, 2006 | 11:58 PM
anyone know the answer to this?
if anyone could helpwith this i would really appreciate it. or if i could be directed to a site with some wiring info.
thanx
Old Oct 10, 2006 | 01:05 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I'm not familiar with the Impala wiring, but if it is similiar to the F-body the short answer is no. Was the VATS programed out of your PCM? If not you will need one or a bypass module. On my 95 T/A harness there is a 10 pin (C100 I think) that is going to need power to a couple of pins. See LT1 Swap He has a short hand version of what needs to be hooked to what. 4th Gen LT1 F-Body Tech Aids has a lot of wiring info, though again F-Body.
Old Oct 10, 2006 | 10:36 PM
yes the vats was programmed out, and i already jumped the starter-interrupter relay under the driver's kick panel. thanx for the info
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
