2.8 to 350 swap questions?
Old Oct 16, 2006 | 08:45 PM
fg_stadium's Avatar
88 camaro 2.8 t-5,can I use the stock power steering pump, hei distributer and anyway the 350 will bolt up to the stock 2.8 t-5?
Old Oct 16, 2006 | 09:16 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Steering pump wont work because the bracket is different. If you could fab a way to bolt ur existing pump to the 350 ud be set, and the distributor definately wont work, dont try it. maybe someone else could shed light on the T-5, i know for an auto trans, like the 700r4, you dont wanna use a v6 tranny on the v8 because the hydro pump is different and it will cause premature wear, not sure about the t-5s though. Good luck.
Old Oct 16, 2006 | 10:39 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
The V6 car has a different bell houing(will not mate to V8), Transmsission has a different spline count(V6=14 spline V8=26 spline, clutch disc is smaller in diameter. So no the 2.8 T5 will not bolt up to a 350
bellez77
Sep 5, 2015 08:39 PM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
