5.0 tpi to 5.7 swap
Old Oct 26, 2006 | 08:34 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
5.0 tpi to 5.7 swap
Does anyone know if a 1987-1995 350 TBI engine will run properly if installed in my 1991 Z28 which is currently a 5.0 TPI. I want to keep the TPI setup, but I'm not sure if the speed density system would allow the engine to run properly. I know I might have to change the injectors, and prom chip, which is not a problem. Will the stock TBI cam effect this setup? Please help I don't know much about TPI MAP systems.
Old Oct 26, 2006 | 11:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put a 350 TPI engine in it, put in 22 lb injectors, change the knock sensor and module to 350 pieces, put in a 350 TPI PROM, and it will run just fine.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
