IT'S ALIVE...SWAP DONE
Old Dec 11, 2006 | 02:53 PM
BIRD-VERT92's Avatar
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
Just fired up my 388ci this weekend. swapped into my 92 3.1L vert. Just a little info for any one else doing the carb swap in a 92. I left the ECM in the car, and only used the wires I needed. The car has vats, but I did nothing to the circuit, and it starts right up. The fuel pump still primes for a couple seconds when you turn on the key, and runs after oil pressure builds up. I did nothing to the wiring in this circuit either. the temp and oil guages work just fine. The tach works but is way high. I ran a new circuit for the fan, so I don't know if it would have worked or not. The speedo is working just fine also, and I changed nothing there either. The only thing is the "ses" light, but I knew that would be on. Looks like in a 1992, alot of the wiring mods aren't needed if you leave the ECM in. Runs real good, just need to address the rear end now.
Old Dec 11, 2006 | 04:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The tach is assuming every 3 ignition pulses equals one revolution. In your case, 4 pulses equals one revolution, so it is reading 33% too high. You either need a V8 tach, or the circuit card from one.
I hope you're using a return-style fuel pressure regulator.
The easy cure for the SES light is to remove the bulb.
Congrats on getting it running!
Old Dec 23, 2006 | 08:02 PM
mightymouseman's Avatar
Car: used to have red 1991 camaro RS
Engine: with 305 TBI
Transmission: Borg Warner T-5
Axle/Gears: and 3.08 open 10 bolt
congrats. IMHO, the rear end and transmissions are the weakest parts of a 3rd gen. take care of the drivetrain and you will have one heck of a car to play around in.
