anyone using this radiator setup?
Old Jan 4, 2007 | 03:11 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
I'm swapping an LT1 into an '89 RS that originally had a V6.
I went with the radiator from the '89 IROC b/c everything bolts in much easier.
Now I need to find a lower radiator hose. The stock upper hose for the LT1 works fine, but the lower one is too small to fit over radiator outlet.
Anyone know a part nbr or an application that would fit? I've walked a few parts stores back rooms and nothing yet.
Old Jan 4, 2007 | 08:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
By how much is it 'too small'?
I had that problem with my Griffin rad... the lower outlet was about 1/8 dia too big, but a little oil on te inside of the hose and a little massaging got it on there.
Old Jan 4, 2007 | 08:52 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I use a 92 Corvette hose on mine. I had to cut a little off of the lower end to move it away from the idler arm.
Old Jan 5, 2007 | 08:50 AM
Car: 1989 Camaro RS
Thanks, I'll try the '92 Vette.
Air Adam, the lower neck of radiator is 1-3/4" and the lower LT1 hose is 1-13/32", so it's almost a full 1/2". From what I've seen most of the lower hoses for the late 80's IROC are 'flared' at the rad neck, so it is just a larger size hose than most where it fits the radiator. It was so small I didn't even try greasing it, but if I don't find a hose I like I just may try it.
Old Jan 5, 2007 | 09:21 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I am also using the thirdgen radiator and dual fans so, I know this hose will fit your setup. On my cardomain site you can see the top of the hose in one of my pics.
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
