L98 Replacement "need some help"
Old Jan 6, 2007 | 12:54 AM
res1bxh3's Avatar
hey ive been waiting on funds and now have come to a point where i can get my 89 iroc running it has a l98 in it with a bad knock so im just goin to replace it. now from what i understand this engine right here is a direct replacement http://paceperformance.com/index.asp...D&ProdID=42913 is that correct? also im having trouble figuring out the other parts i need to complete this. I will be having the heads redone and would like to also get a new oil pump and pan because the oil from the current engine have some shavings in the oil and i dont wanna have to worry about the pump. So with the exception of the heads what do i need to complete this engine also ive been looking at the LT-4 Hotcam for this whats your opinions about that combo.
Thank you very much for your time,
Edy Lopez
Old Jan 6, 2007 | 08:02 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
well,
you'll need a full gasket set, your cam and lifters the hot cam looks great!), a timing chain (don't skimp here cloyes is who i trust), a timing cover (old one is probably "tweaked from overtightening), new head bolts, retune or remove the computer (i didn't say that), you can reuse or replace everything else as needed.
ok guys,i'm tired! but that's a start.
what did i miss?
Eric B
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
Winchester1094
Aug 18, 2015 10:23 AM
