FUEL PUMP ?????
Old Feb 17, 2007 | 10:01 PM
zmack28's Avatar
FUEL PUMP ?????
Ok, I am doing the swap, im am at the point of fuel. I am putting a lt1 into a 89 camaro with that had a 305 TBI. I have read all the info about changing the fuel lines and pump. however i have never worked with in tank fuel pumps (looks easy enough) however my question is:
1. Do I need to change the whole thing? IE the pump and sending unit?
2. if so, I seen a complete set up (sending unit and pump) on ebay that came out of a 93 vette, will that fit?
OR
can i just buy the pump, pull out the unit, replace the pump, and be all set?
Thanks for any info
Old Feb 17, 2007 | 10:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Buy the pump (Walbro 255 is the best) replace it and put the sending unit back in, be careful though when pulling the sending unit out and not damage the piece that controls the gas gauge.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
