how to tell if its 2 or 4-bolt
Old Apr 16, 2007 | 03:12 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
How can you tell if its a 2 or 4 bolt inside the car, my car originally had a 2.8 and was swaped to 350, they removed the 350 and now i have the car with no engine, but motor mounts are still in place, how can you tell weather its a 2 bolt or 4 bolt that must be used, if this has anything to do with this, thanks!
Old Apr 16, 2007 | 03:19 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: how to tell if its 2 or 4-bolt
The V8 motor mounts in your car will work with any Chevy small block (except LSX) regardless if the block is a 2 or 4 bolt main.
Old Apr 16, 2007 | 03:23 PM
Transmission: th350
ok i'm sorry, thats good to know, i thought that 2 or 4 bolt met how it was mounted, stupid me, but what does it mean?
Old Apr 16, 2007 | 03:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How many bolts hold the main caps on.
Old Apr 16, 2007 | 03:38 PM
Engine: 400
... And the main caps are what hold the crank in. On a 350, a 4 bolt is stronger than a 2 bolt.
Check out this article on howstuffworks. It's a great learning tool about how engines work.
http://auto.howstuffworks.com/engine2.htm
FstBrd6point3
Feb 24, 2005 08:04 PM
GlenYappa
Oct 31, 2001 04:53 PM
G92Joe
Sep 3, 2001 10:55 PM
james_fearn
Aftermarket Product Review
Jul 20, 2001 06:46 AM
TRAXION
Oct 30, 2000 10:45 AM
