FUEL SYSTEM in tbi-carb swap ????
Old Apr 24, 2007 | 09:23 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
Hey Im starting to do the fuel system stage in my tbi-carb engine swap, I got a carb gas tank pickup, external fuel pump, and the mallory 3port return style regular( i think p/n 4309). The regulator is where im lost. theres 4 holes around the body of the regulator and a hole on the bottom thats labeled BYPASS. is the bypass supposed to be for the reuturn line? and since i wont be using all 4 holes that go around the regulator can i just plug them? thanx in advance
ps. and also how about wiring the fuel pump? can i wire it into the connector that is near the fuel tank(underneath car)?
Old Apr 29, 2007 | 10:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"BYPASS" = "return". Plug what else you don't need.
You can use the stock wiring.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
