swapping 7730/406 tpi to 94 firebird. which wires on harness need energized/grounded
Old Apr 27, 2007 | 01:23 AM
87_TA's Avatar
If anyone does not know I totaled my once beautiful 10 second 87 trans am - decided to pick up a 94 v6 firebird as a trans plant car for my 406/t56 combo that was converted from 265 - 7730 ecm - probably a backward swap - but still a good engine..
Anyway just pulled harness from trans-am, noticed there are (3) connectors split off of ecm harness to under dash - one connector is a,b,c,d,e,f,g,h,
other side is j,k,l(not used),m,n,p,r. the a small 6 pin that uses A,C,D,..
mY Question is, are any of these wires needed? if so which ones..
Basically what pins must I ground,power,ign power to energize this thing in the car..
Will also post on engine swap board..
Old Apr 27, 2007 | 10:12 AM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
Re: swapping 7730/406 tpi to 94 firebird. which wires on harness need energized/grou
you might wanna try the diy prom board... all kinds of pin out diagrams and stuff floating around there...
406 tpi? i'm putting together a tbi swap - what did you use for your knock sensor, the 350 unit? any problems with false knock counts?
Old Apr 27, 2007 | 10:49 AM
87_TA's Avatar
Thanks,
I have pinout diagrams, but the connector for under dash is split off ecm harness, just figured someone would know off hand..
No problems with knock prior - but I disabled that a long time ago for racing consistancy via prom..
midge54
Sep 2, 2020 07:13 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
