Engine swap fuel pressure question
Old May 9, 2007 | 10:12 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I am swaping a TPI injected 350 with a carbed 383, I was worried about the pressure that the TPI pump puts out, would a holley fuel pressure regulator designed for a carb effectivly knock that pressure down. I plan og getting the pressure regulator with the bypass option.
Any suggestions or comments?
~Nick~
Old May 9, 2007 | 11:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine swap fuel pressure question
That would be fine. A bypass regulator with a return line is essential, using a deadhead regulator with an internal bypass will burn up the stock pump in short order.
Old May 10, 2007 | 10:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Mallory #4309 is a very common suggestion for a return-style regulator.
Old May 10, 2007 | 10:35 PM
FastEddiesIROC's Avatar
That Mallory is the regulator I use and have never had a problem
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Kaweh
Aug 9, 2015 02:54 PM
