t56 flywheel for a 400sb
Old May 16, 2007 | 12:59 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
im going to go look at a 400sb and im soon installing a t56, how can i make this work...
can i buy an internal balance stroker crank?
are there conversion flywheels out there for this application?(ext. bal.)
what would you do?
Old May 16, 2007 | 01:28 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: t56 flywheel for a 400sb
so you want a 400sb, which has no flywheel or crank?? you can get an aftermarket crank that has internal balance, but its gonna be forged and cost a pretty penny.. dont see why you need it.. external balance stuff is just as good.. as for the t-56 part, no ideas here.. i'm still stuck with my t-5.. all i know is that a 400 flywheel doesnt fit in a stock t-5 bellhousing..
Old May 16, 2007 | 09:36 AM
Centerforce 700173
Old May 18, 2007 | 11:36 PM
lincolnpark773's Avatar
Before I had my big block bolted to my T5 I had a 406 in my 84TA. The part I used was an external balanced 153 tooth made by Hayes. It turned out to just be a standard zero balanced 153 with about 5 3/8" holes drilled into the opposite side of where the weight is normally attached. I asked the guy who balance my motor if I could have just purchase a standard zero balance wheel and have him drill the holes and he laughed and said yes. I felt like a moron.
Old May 20, 2007 | 02:21 AM
Engine: 350ci
sofakingdom thank you very much
do you have any recomendations for a balancer?
Old May 21, 2007 | 09:26 AM
Any good quality balancer for a stock 400 will work. The best of course would be the $ATI$. For a good quality stock replacement grade one, use a Pioneer.
Yes it would be possible to use the neutral-balanced "swap" flywheel to put the T-56 behind a 2-piece RMS motor, and have it "unbalanced" to the stock 400 spec; not a problem. My T-5 one for a 400 was done that way and worked fine for a VERY long time. Only thing is, I think you would find that it will cost more in this particular case to do that, than to buy it already done. No matter what, it's still a "special" "swap" flywheel. A little different situation from the possibilities when there's some stock flywheel you can do that to, or even some relatively cheep aftermarket one.
Old May 22, 2007 | 02:28 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Centerforce 700173
2nd that. Thats what I have behind my 406.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
