1987 camaro i roc-z28?I'm Confused
Hello,I just brought a i roc-z28 5.7 and i know very little about these cars,heres my problem?I compared my camaro to other to make sure that i have a true 350 and i'm drawing blanks.I looked at the 305 tpi engines and the alternators are on the left and the a/c compressor are on the right but thats not all,I look at some other i roc z28 5.7 and there alternator is on the right also and the engines look identical to the 305 how to tell wether or not mines is a 305tpi or a 35tpi it seems to me they switch the engines around all the dam time please help me
350's
alternator on the right ,and a/c compressor on the left,is it a true 350,but some 305 are the exact same?
305's some are the same alternator on the right ,and a/compressor on the left and some are alternator on the right and the a/c compressor on the left someone please help
350's
Transmission: 4L80E/4L80E
The alternator is located in the same place whether 305 or 350. The difference in location has to do with the year of the car, not the size of the engine. 350's weren't offered until 1987. Even then, the alternator was on the right (passenger side). It moved to the driver's side in 1988.
One way to know what engine was delivered in the car is to look at the 8th character of the VIN - if it's an "8", it had a 350. If an "F", 305.
But, that still doesn't tell you what engine you have. The only way to know for sure is to get the block casting number, which is located behind the driver's side head on top of the bell housing casting of the block. Not easy to see, but easier than the next best way - pull the head and measure the cylinder bore.
beachrodder
Aug 25, 2015 08:05 AM
