Fuel Pump TPI TBI Question?
Old Jul 22, 2007 | 06:37 PM
ChampionN84's Avatar
Car: 91 Camaro Z28
I had some questions about the swap i am doing to my car. I am swapping the fuel pump out because of a tbi to tpi swap. I have the fuel pump from the TPI car but there is this thing that was attached to it, (Should i reattached it or just put a hose on it like the tbi was?) Also what screen should i go with. There is two difference between the both? One is in the middle and one is on the side. Which one?
<img src="http://003330d.netsolhost.com/car/1.jpg">
<img src="http://003330d.netsolhost.com/car/2.jpg">
<img src="http://003330d.netsolhost.com/car/3.jpg">
Old Jul 22, 2007 | 06:48 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Fuel Pump TPI TBI Question?
Fixed the links for ya.....
Old Jul 22, 2007 | 06:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Pic 1 is a fuel pulsator to try to quiet the noise of the high pressure pump. Its up to you if you want to install it or not. Most of us just remove it and put some high-pressure fuel line in its place. Make sure you use high-pressure fuel line.
The location of the hole for the screen doesnt matter. Just put a new one on it with the pump.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
