Blueprint Crate Motor Questions
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
I am looking at the 355 blueprint crate engine listed on the website below. It is a 1 piece rear main 385 hp, 405 ft.lbs..
http://www.blueprintengines.com/popu...specs&pc_id=59
It says that I would need an 8" non-weighted harmonic balancer and a late model 350 weighted flexplate. I am thinking that the stock flexplate from my 89 TBI motor is the correct flexplate but I am not sure about the 8" balancer. I am thinking they are saying a balancer for an internally balanced motor, I've just not heard it called non-weighted before.
Also wondering what size stall converter to go with?
Car is mainly street driven during the nice summer days.
Any help you can give is appreciated.
Transmission: 4L80E/4L80E
You are correct on the damper and flexplate.
That engine would probably like somewhere between 2500-3000 RPM stall.
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Re: Blueprint Crate Motor Questions
I know this is an old post but some people may find it useful. I bought the same engine and it's installed and running great. I bought the following Flexplate and balancer...
B&M 20238 Flexplate
http://store.summitracing.com/partde...8&autoview=sku
Dorman 594-121 Balancer
http://store.summitracing.com/partde...5&autoview=sku
B&M 20238 Flexplate
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
