5.7 Vortec Springs
Old Sep 4, 2007 | 07:42 PM
cleanz_28's Avatar
Car: 1987 Chevrolet Camaro
Engine: Vtec Killer
Transmission: the kind that loses Hondas in 1st.
Axle/Gears: the kind that turn the wheels
5.7 Vortec Springs
So Im geting a 5.7 Vortec engine rebuilit,What do I tell the Rebuliders If I want sbc springs,also what spring should I get ? what cam would be good for it.
Im putting on the GMPP intake so I can use my tpi.
Old Sep 8, 2007 | 10:02 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
Re: 5.7 Vortec Springs
The gmp vortec 330 uses 1999 l31 springs.
Old Sep 8, 2007 | 10:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you put the Comp Cams 918 Beehive Valve springs and retainers on them you can use any cam you want up to .550" lift.
Old Sep 9, 2007 | 05:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Manley 22410-16 springs and 23652-16 +.050" retainers will also fit and allow you to use a camshaft up to .550" lift. I think they're less expensive, but I'm biased.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Lanz06
Sep 14, 2015 07:16 PM
sandman92084
Sep 12, 2015 10:27 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
