ls1
Old Sep 4, 2007 | 10:37 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
ls1
im sure its on hear some were but im to lazy to look it up. but what all do u have to do to make the ls1 motor fit in a third gen camaro? and can the six speed trans fit in with it?
Old Sep 4, 2007 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a sticky in the top section of this forum. If you're too lazy to look at that, I'm too lazy to help you.
Old Sep 5, 2007 | 07:29 PM
Diabloformula's Avatar
Re: ls1
Old Sep 5, 2007 | 07:38 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: ls1
Too lazy to search, too lazy to actually go through with the swap. So why would you need info about it?
Old Sep 6, 2007 | 11:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: ls1
to answer your question...
you need a...
ls1 and a 3rd gen f-body
Old Sep 7, 2007 | 09:46 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: ls1
it bolts in.
it always bolts in.... to anything... you only need 3 bolts... two engine mount bolts and a trans mount bolt.
if you want something more specific.. then ask a more specific quesiton.
"how does an LS1 install go?" is not a specific question.
"how do i connect the head bleed hose to the thirdgen radiator?" is a specific question, that i would be happy to answer.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
