Fuel Pump Relay Question
Old Sep 23, 2007 | 07:37 PM
fredtx92's Avatar
Car: 1992 Camaro Heritage T-Top
Engine: 1993 LT-1
Axle/Gears: 3.42 disc rear from 4th gen
Hello Everyone,
Newbie here.. I have a question and have searched the board thoroughly and can't find my answer. Any help will be appreciated. Question is, I have a 1992 Rs 305 tbi I have put an LT-1 in from a 1993 Z-28. I need help with the fuel pump relay. I have cut all the wires from the relay. What all needs to be hooked up for the fuel pump to work? Thanks in advance.....
fredtxfireman27@yahoo.com
Old Sep 24, 2007 | 02:20 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Fuel Pump Relay Question
did you cut the wires from your 92 or the 93 donor car? also did you get the fuel pump from the donor car? the TBI pump only produces around 15PSI and your LT1 will need around 45PSI.
Old Sep 24, 2007 | 08:55 PM
fredtx92's Avatar
Engine: 1993 LT-1
I cut the wires on the 92 car because the fuel pump relay was wired into the wiring harness. I just need to know what needs to be hooked back up for the fuel pump to run. I am going to put a TPI pump in it this weekend.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
