hood clearance, BBC
Old Sep 24, 2007 | 04:34 PM
coldblooded's Avatar
hood clearance, BBC
is it at all possible to fit a BBC under a stock hood? if so what needs to be done? im looking for a 100% sleeper car, no cowl no modifications to the outside at all, ive done a small block swap and know i can fit it under the stock hood, but wondering how close it is for a big block.
Old Sep 24, 2007 | 04:49 PM
Re: hood clearance, BBC
i did see in the bbc swap info at the top that with a low rise and a slim air cleaner it should be possible, but i want to know if anyones seen it or knows for a fact.
Old Sep 24, 2007 | 04:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not if you want any clearance between the airhorn and air cleaner lid.
How about a big-inch small block or LSx?
Old Sep 24, 2007 | 05:57 PM
yeah i do have a back up plan, i know where i can get my hands on a 400 small block already bored to a 406, for pretty cheap. but i would much rather have a big block tucked under the hood. i dont car is its tight, as long as i can close the hood and it'll still breather alright. what about using a drop base air cleaner along with a low rise intake.
Old Sep 24, 2007 | 06:13 PM
five7kid's Avatar
The only "low rise" intake I know of is the Edelbrock single plane (Tarantula, if memory serves). Terrible piece performance-wise.
Old Sep 24, 2007 | 06:24 PM
rabrand's Avatar
I have a Torker II on a 396(not in a 3rd gen) its a pretty low profile manifold.
Old Sep 24, 2007 | 06:27 PM
five7kid's Avatar
That's another one.
And, completely non-performance.
Old Sep 24, 2007 | 07:31 PM
i was reading a bit in chevyhiperformance's site, about a 400 build they did, and i noticed this blurb "While the big boys play around with 434ci, 440ci and even 454ci small-blocks"
does anyone know anything about these 440 454ci small blocks?
Old Sep 24, 2007 | 07:35 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
aftermarket block involved
what small block do you currently have?
Old Sep 24, 2007 | 09:13 PM
o thats a bummer, guess im going to start researching building a mean 406.
whats the highest a 400 can be bored out too, i havent played with them much not the most common blocks
right now the car in question is not a v8, my other camaro i just swapped in a 350, its nice, but bit too common
Last edited by coldblooded; Sep 24, 2007 at 09:16 PM. Reason: Automerged Doublepost
Old Sep 24, 2007 | 10:34 PM
five7kid's Avatar
.030" is typically the max safe bore on a factory 400 block. The aftermarket blocks can typically take a lot more.
The aftermarket really did their homework on these. The cost of the block is certainly less than what you'll waste when a factory block breaks.
Old Sep 24, 2007 | 11:21 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
i just finished putting in my bbc, it fits under the stock hood with a edelbrok perfromer intake and a quadrajet carb, not much room for an aircleaner tho, but i havnt taken any of the support out from under the hood
Old Sep 25, 2007 | 10:21 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Contact Bill Mitchell Racing Engines for big cube small blocks. Be prepared to spend money. If you already have good heads, intake, valve trane, they also make short blocks of 383, 415, 427, and 454.
Not sure what there website is, do a google search.
Good luck,
Old Sep 25, 2007 | 10:50 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You can go about .060 on some blocks. Depends if the wall thinkness is great enough, and even so, it's not recommended to go that far. 400's are great. What kind of numbers are you looking to make?
Old Sep 25, 2007 | 12:42 PM
five7kid's Avatar
It's not a bad idea to have any factory 400 block sonic tested for wall thickness before spending any money on machine work or parts for it. This is in addition to magnaflux for cracks.
Old Sep 25, 2007 | 01:34 PM
Engine: 400
What is the minimum recommended wall thickness? Do you know off hand?
Old Sep 26, 2007 | 11:55 AM
as far as the numbers im looking more for a torque motor, which is why i was so interested in the big block, i could take a very lightly modded 454 and get the kinda torque i want, im thinking somwhere around the low 400's for torque(from the motor now rear wheels) im not the kinda guy that opens up the motor full bore to realy expeirence the top end, im more into the bottom end of things. i like the power my 350 has, but its just too common of a motor for me
Old Sep 26, 2007 | 01:28 PM
Engine: 400
Chevy High Performance did a build with a 400 small block and vortec heads. The motor made 525ft/lbs
Old Sep 26, 2007 | 04:25 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
The early corvettes used a spread bore manifold on the 390HP 454, it will allow a full air cleaner under a stock hood, no problem.
Old Oct 4, 2007 | 07:58 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
edelbrock made a c427x intake to fit under the corvette hood. it fits under my 2" cowl with a 3" k&n drop base air cleaner and a 1/2" nitrous plate.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
mr z28
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
