87 Camaro 400 trans swap
Old Oct 11, 2007 | 11:03 AM
bawhitman01's Avatar
Car: 87 camaro/73 Mustang
Engine: 350/351C
Transmission: T-5/C6
Axle/Gears: 2.73 Posi
Does anyone know where i can get the parts needed to make the swap and what all is needed to perform the swap???
Old Oct 11, 2007 | 11:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Could you be a little more specific about what you're swapping? A 400 engine, or TH400 transmission?
What are you wanting to install?
Old Oct 11, 2007 | 11:55 AM
Engine: 350/351C
Re: 87 Camaro 400 trans swap
Sorry I am swaping from a 700r4 to a T400 transmission
Old Oct 11, 2007 | 02:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Different transmission crossmember because the mount sits farther back. Preferably a crossmember with a mount for the torque arm on the crossmember which means normally buying a new torque arm with crossmember from companies such as www.spohn.net
Shorter driveshaft with a different transmission slip yoke.
Electric kickdown switch.
Maybe a different flexplate as the TH400 has a different bolt pattern than the 700R4/TH350 unless you already have a dual bolt pattern flexplate.
Old Oct 12, 2007 | 02:49 PM
five7kid's Avatar
The TH400 mount is farther back from the bellhousing face than the TH700, but the TH700 total length is longer than the TH400, so a longer driveshaft is needed when swapping to a TH400 from a TH700.
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
The_Phoenix
Sep 3, 2015 10:56 PM
camaro71633
Sep 1, 2015 10:24 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
