383 into 92 rs
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
383 into 92 rs
Would a 383 directly go into my RS if i did a motor swap? What ecm could i use for it? Here is a cheap 383 crate motor for tbi on ebay.
http://cgi.ebay.com/ebaymotors/CHEV-...QQcmdZViewItem
I would need..
- 350 injectors
- Fuel pump
- New throttle body unit
- different ecm
what else?
I would need..
- 350 injectors
- Fuel pump
- different ecm
what else?
Transmission: 4L80E/4L80E
That's closer than most would be, assuming the seller delivers what they say.
I can't imagine TBI heads supporting a 383, but perhaps I just don't have as much imagination as the seller. Notice no power figures are given. I was going to say figure on replacing all of your stock exhaust, but with TBI heads, maybe it won't matter.
You wouldn't need a different ECM, just a tuned PROM.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: 383 into 92 rs
i had an ostrich emulator and datalogging equipment but i recently sold it. im not really interested in tuning again because it takes too long, is there anyway i could get a chip other than tbichips?
LT1Formula
Oct 8, 2015 08:34 PM
