sbc 406 swap (death vibration)
Car: camaro
Engine: 350 chevy
Transmission: super t-10
Whats up! I've been having a bit of trouble i have a massive vibration that begins at 2000 rpms and dies off under load untill 3000 rpm then its a eathquake inside the vehicle. The motor was rebuilt stock crank stock rods stock heads 30 over trw pistons 10:1 t-10 4 speed stock rear..... What i've done:had the trans checked 3 time,new balancer, new flywheel, new cap and rotor, new wires, new coil, new distributor, new plugs, checked for vacuum leaks, checked for missfires under loads, i had checked the flywheel weight to the weight on the original gm flexplate that cameoff the motor it was dead center, i have also checked my exhaust for excessive back pressure. p.s. the motor vibrates in nuetrul even at a stop while in gear.. If anyone knows if tis is normal please let me know and will it whipe my bearings Thanks Elie
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: sbc 406 swap (death vibration)
Uh, definitely not normal.
If it's shaking in neutral, and you've checked the balancer and flywheel - then it's inside the engine.
Did you have it balanced?
I'm guessing something went wrong. Left a piston out or something REALLY big and heavy. I know you can't get the oil pan off with the T-10 in there, so I think you're going to need to pull the engine out and pop the pan off and see what's going on.
Side note - when you changed the plugs, was anything amiss with any?
Car: camaro
Engine: 350 chevy
the balancing was done at the machine shop as well as the block and crank, piston pins rods and bolts.I assembled it i know that all eight pistons are in there i had done a compression check they all were 190 psi but i have done a checkwhere i had removed everything up to the flywheel and started it it was smooth and then i installed the clutch and it was smooth then the bellhousing and trans and it was smooth when i put the crossmember and exhaust up and put the car on the ground it felt like a WOBBLE at 2000 then smooths out to 2800. at 3000 i can hear my plastics rattling and also hear the vibration through the sheet metal of the car witch is pretty intense. after a 10 min ride cant feel my legs p.s. it dosent shake from idle to 1800 at all thanks Elie
Car: 1986 Trans am
Engine: 409 SBC Vortec Heads Lunati 0011
Axle/Gears: BW 9 bolt 3.23 posi
You can only use a flywheel and front damper made for the 400 sbc. This engine is externally balanced. If you used the ones from the old 350 that is your problem.
Car: camaro
Engine: 350 chevy
hey! i have a brand new externally balance flywheel and balancer.....But i have heard thet the 454 and the 400 are a very close balance and the might have packged a 454 flywheel instead of a 400 fywheel, so i am going to get a new flywheel and try it out and hope for the best..Thanks Elie
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Did you ever get rid of the vibration?
Car: 87 Formula
I had my Torque Converter replaced with a stock replacement for a vette, the vibration is now gone.
