help!!!!! TPI swap question!
Old Jan 22, 2008 | 12:15 AM
CamaroCarnage's Avatar
so i pulled the motor and harness outta my car today and noticed the tpi harness and the LO3 harness are generally the same, but the LO3 harness has 2 extra pins in the harness. anyone else notice this? are they important wires? ahhhh
Old Jan 22, 2008 | 01:02 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: help!!!!! TPI swap question!
You really need to be more specific. What year is the car, what year is the harness. Where are the pins located?
Old Jan 22, 2008 | 01:20 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
This link should be the Schematics for the 86-89 TPI ecm
http://chevythunder.com/198689_f__y_body_1227165.htm
This link should be a Schematics of the lo3 ecm
http://chevythunder.com/1228746_ecm_198992_tbi.htm
print them out and compare. You will find that several pins differ from one to the other. I used my lo3 harness for my TPI but a few pins had to be moved. The schematice links are the very ones I used
This is a link to the tpi ecm pinout, it will help but I can't find one for the lo3 so you will have to trace each wire down.
http://chevythunder.com/fuel%20injec...ecm%20#1227165)
You will also have to do some work to the engine end of the harness to make it work. Again, use the links
If I can help let me know,
Dewayne
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Sanjay
Aug 12, 2015 03:41 PM
