new z28 350 question
Old Feb 13, 2008 | 10:49 PM
bigjsmashman's Avatar
I just got a sweet 85 z28.i was told that the 305 had been removed,and 350 put in.I am a decent mechanic,but I usually work on european cars.So i wanted to know how to tell for sure that its a 350..
any info will really help
Josh
Old Feb 13, 2008 | 10:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: new z28 350 question
Check the casting numbers on the block. http://www.mortec.com/location.htm
Old Feb 13, 2008 | 11:10 PM
so theres no visual differance?
Old Feb 13, 2008 | 11:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
None at all. Small block chevy engines of similar vintage are externally identical (except for some rare oddballs). That's part of their appeal.
Old Feb 13, 2008 | 11:18 PM
That sux.So basicly I have to get under the car and check the back of the engine.
Old Feb 13, 2008 | 11:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On top of the engine behind the driver side head, but that doesn't make it any easier to look at. Later blocks make it easy with a big 5.0 or 5.7 cast in raised numbers, and usually have the last 3 letters of the casting number on the sides of the block (although those have occasionally been wrong). Earlier blocks you'll need to find the whole casting number behind the head.
Old Feb 14, 2008 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Often the last 3 digits of the casting number are on the side. They are the ones that are the most important, anyway.
Last weekend I helped my brother replace the engine in his '92 Suburban. Both the old engine and the rebuilt engine had "638" cast on the side. Same casting I have in the Camaro right now.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
