350 to 350, Cam questions
Old Feb 14, 2008 | 10:35 PM
ChoobinatoR's Avatar
So i'm working on an bare block 350 engine that came from a 88 suburban, and so far this rebuild kit is going to be ordered tomorrow morning.
http://www.naparts.com/ProductModelD...ctModelId=3741
Comes with a cam of my choice, and I'm open to suggestions/opinions because most of you are more experienced than I. (first swap, woot!!)
The car should be bone stock except for the full 350 swap previous owners did.
Goals for the car:
Streetable, keep TPI, have decent MPG for a daily driver, but I want to be able to smoke any *****s at a stop light, and perhaps fast enough to run away from the popo if needed Haha, kidding on the last one.
Alright, I'll be on for a while, bout to drink a rockstar and go back to my work. Any comments welcome!
Old Feb 14, 2008 | 10:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Maybe I'm missing something, but I don't see an option for the cam, just "Federal Mogul Camshaft".
Don't much like the looks of "Federal Mogul recessed head Pistons", either.
Old Feb 14, 2008 | 11:17 PM
Re: 350 to 350, Cam questions
Yeah I can call in and get pretty much whatever piston/camshaft they carry
I'm goin with a rolling camshaft I know that much, my teacher said their pistons are pretty solid.. what looks bad bout those pistons? =X
****, I'm tryin to remove the crankshaft dampener - anyway to do it without the special tool? O_x
That and the PS pulley I have left to remove.. gonna see if I can do anything else, afk
Old Feb 15, 2008 | 12:10 AM
five7kid's Avatar
Originally Posted by ChoobinatoR
Yeah I can call in and get pretty much whatever piston/camshaft they carry.
Which I assume raises the price.
...my teacher said their pistons are pretty solid. what looks bad bout those pistons? =X
Dished, or higher pin height. They will lower the compression.
No. Use the special tool.
Old Feb 15, 2008 | 12:30 AM
Word.
Recessed pistons no good. I'm researching how I can up my compression now.
Thinnest head gaskets I can go with, stock heads, some well designed pistons (gonna look em up right after this).
Now I need to play mix and match it looks like =/
Here it goes.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
