LB9 heads vs. 462624's on my tpi 305 to tpi 350 swap
Old Apr 16, 2008 | 10:09 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
looking for pros and cons. thanks
Old Apr 16, 2008 | 10:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Between those two, all of the pro's go to the LB9 heads and all the cons to the 624's.
Unless you're looking for door stops.
Old Apr 16, 2008 | 11:07 PM
Re: LB9 heads vs. 462624's on my tpi 305 to tpi 350 swap
the doner engine im installing for now is a 84 cfi 350. the heads are 76cc. will my 58cc lb9's at too much compression? the engine is a 14010207.
Old Apr 17, 2008 | 03:55 PM
five7kid's Avatar
The block casting #, while somewhat informative, doesn't say anything about the pistons that are installed, which are what is critical in determining CR.
No matter how you slice it, 624 heads are horrible. Until they are gone, there isn't much you can expect performance-wise.
The 416 heads can be worked to increase the chamber size if necessary. 1.94" intake valves, basic port clean-up, and valve de-shrouding will probably get you there. And that's just assuming the pistons are flat tops with 4-valve reliefs, which probably isn't the case. And, they'll out-perform 624's, even if the 624's have 2.02/1.60 valves.
Old Apr 17, 2008 | 05:59 PM
are 416's stock lb9 heads?
Old Apr 17, 2008 | 06:06 PM
five7kid's Avatar
For '85 & '86, yes. '87-up had 081's.
Fast355
Dec 2, 2016 06:33 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
drathaar907
Aug 10, 2015 07:44 AM
gwade12
Aug 8, 2015 08:17 AM
