Need help decoding block numbers
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Hello, a friend of mine recently purchased a 1928 Chevy Coupe, it has a small block chevy mystery engine. He is considering upgrading the engine and I might be interested depending what it is.
Due to the setback of the engine I could not get the casting numbers off the top of the bellhousing.
I got the numbers stamped in the block just in front of the passanger side head, hopefully someone can tell me what they mean.
C61124175 followed by K1121TYZ
Thanks in advance.
-Robert
Thanks in advance.
-Robert
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Need help decoding block numbers
C61124175
Last part of the original vehicle's VIN number
K1121TYZ
K = St. Catherines, Ontario assembly plant (The engine was made in Canada)
1121 = Nov 21
TYZ = 1975 350. 165 HP, 4bbl. Conventional cab pickup truck.
It's probably an 010 casting 4 bolt block.
K1121TYZ
1121 = Nov 21
