Ahh! 82 Maro???
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Ahh! 82 Maro???
Well, i just got done building a L98 TPI, all new guts.. runs great on the dyno, but she isnt rolling any wheels yet.. as in, IT NEEDS A CAR
I found an 82' Z28 locally, going for $250. Body is perfect, has no motor or trans in it, and she needs some interior work (perfect summer project?)
My question is, I know that 82 came stock with a carb, and im not sure if the dash, guages.. etc is different from the TPI jobs. And i definitely want to run TPI.
What kind of hell will i run into if i get a dash harness, engine harness and ECM from a 86', and throw it in there?
What will/wont work.. what kinda joberew is this going to be? Any support is greatfully appreciated.
Car: Blue 89' RS
Engine: 5.7L
Re: Ahh! 82 Maro???
wiring is cake if it is uncut... less than 1 days work (gutting the 82 and putting in 86')... if you remember how you took out the 82 stuff
do yourself a favor.. use a digital camera before you pull a wire off.
Transmission: 4L80E/4L80E
I didn't do TPI, but I did swap the whole '86 dash ('82 was a V6). The only issues I had were the passenger kick-panel bulkhead connector was larger for the V8 (just opened the hole up a little), and the connectors to the rear chassis were different (had to find schematics for each year/car and re-do the chassis-side connectors).
ElPaleterro85
Aug 13, 2015 03:49 PM
Christos
Jun 6, 2003 05:51 PM
Gen X Mar0
Aug 29, 2001 04:37 AM
fb305svs
Dec 10, 2000 06:26 PM
