455 question
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
455 question
I working on a deal to purchase a 455 motor. My question is, Are all the Buick,Pontiac,and Olds 455 the same motor. You know like how they used Olds 403's in 2nd gen T/A's. I've always been more of a small block man and I don't have a lot of knowledge on the larger displacement motors. Any help would be great.
Transmission: 4L80E/4L80E
Buick, Olds,and Pontiac each had their own design for their 455.
The only one I've seen any 3rd gen support for is the Pontiac. See sticky above.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 455 question
Only from 77-79 did GM put the Olds 403 into the Firebird but only after dropping the Pontiac 455 after 1976. The second gen platform was easier to drop in a B-O-P 455 or Chev BBC since the 2nd gen platform originally came with a big engine at one time.
Because the B-O-P-Caddy engines all share the same bellhousing bolt pattern, it was easy to pull the Olds engine and drop in one of the others for those dihards who still wanted a Pontiac engine under the hood.
By 1982 when the third gens were released, all the f-bodies got the Chev engines except for the few who got the Pontiac 4 cylinder or Buick V6.
