L03 to carb'd
Old Jul 13, 2008 | 03:24 PM
morgsie's Avatar
L03 to carb'd
Hey, I have a quick question about the L03. Swapping an L03 out of a '90 Caprice 9C1 into a friends '80 Cutlass. My big concern at the moment is does the L03 cam have provisions to run a mechanical fuel pump (since it's a TBI engine)? Do I just change the block off plate with the one off his stock 305 and bolt a fuel pump to it and go? Or am I going to run into other problems
My other question is we would like to retain his stock bracketry. I'm pretty sure the water pumps are different, but will changing the water pump to the older style interfere the newer style timing cover? Are the harmonic dampers the same as well?
Anyone else done this swap and have any tips?
Thanks,
morgsie
Old Jul 15, 2008 | 11:59 PM
morgsie's Avatar
Re: L03 to carb'd
anyone?
Old Jul 16, 2008 | 01:13 AM
frostedmonster's Avatar
Re: L03 to carb'd
umm when i took my plate off on my old lo3 in my other camaro and it doesnt have a pick up and the cam doesnt have the pick up thing either cant think of the names but yea
Old Jul 18, 2008 | 06:03 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: L03 to carb'd
Im pretty sure you have to pull the timing cover to install the parts for the mechanical pump. I would just pick up a cheap inline pump and regulator.
Long vs short? I couldnt tell ya if it'll work, I doubt it, just do some measuring.
Harmonic damper shouldnt matter. I would just leave it on the motor.
Old Jul 21, 2008 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have to pull the timing cover to install the fuel pump push rod. The only question is whether the block has been drilled/machined for it, and if the cam has the lobe for it - I've heard people that have seen them machined/not machined, with/without the lobe. Only way to know for sure is to check.
Timing covers won't interfere with the water pump, but many different dampers and timing tabs have been used. The LO3 damper and timing tab shouldn't have any problem with the older water pump/accessories.
Old Aug 19, 2008 | 09:55 AM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Re: L03 to carb'd
I pulled the L03 from my 90 Formula and put it in my 87 Formula. I took the plate off and there were provisions for the fuel pump so I took the parts from the LG4 I took out of the 87 and put them on the L03. Works great.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
