350TPI - LS1 - Help?
Transmission: 4L80E/4L80E
The engine, harnesses, computer, sensors, transmission, engine/transmission mounts, fuel pump/supply system, etc.
Basically, you need to do an LSx swap, which isn't new territory - there's a sticky in the top section of the forum on the topic.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 350TPI - LS1 - Help?
You can, although it's easier to use the 4L60E or 6-speed.
If you look at the LTx/LSx sub forum, there's a sticky.
It's on both forums, actually. https://www.thirdgen.org/forums/engi...want-swap.html
The input shaft length is different. Auto tranny requires a spacer, haven't heard of any solutions for manual tranny other than changing the input shaft.
Did you read the sticky?
I haven't checked lately, but decent engine/harness/PCM were going for about $2k; add a 4L60E another $1k; an LS1/T56/accessories/harness/PCM will run somewhere between $3500-$4k. Figure another $500-$1500 for installation stuff, depending upon what you do for exhaust, gages, fuel system, etc.
